Messerschmitt Bf 109 G6 1/24 Trumpeter
albert091283
Troszeczka na temat pilota tej maszyny. Co prawda nie udalo mi sie nic wiecej znalezc na temat tego konkretnego samolotu ale jedno jest pewne byl pilotowany przez niego i mial oznaczenie "Biale 6 " Z gory przepraszam za angielska wersje
Willi Reschke was born on 3 February 1922 at Mühlow in the Crossen region of Mark Brandenburg. He joined the Luftwaffe in February 1941 and began military training with the Flieger-Ausbildung-Regiment at Königsberg-Neumark. Initially, he trained as a technician but finally began flying training in late spring 1942 on gliders before progressing to powered aircraft at Flugzeugführerschule 51 at Elbing and later at Flugzeugführerschule A/B 9 at Grottkau and Niesse. On 27 June 1943, Reschke was transferred to Jagdgruppe 102, based at Zerbst to undergo his operational training. He then underwent an instrument flying course at Blindflugschule 110 at Altenburg from 21 March 1944. On completion of his training, Reschke was posted to JG 302, based at Götzendorf near Wien, on 20 June 1944. Unteroffizier Reschke was assigned to 1./JG 302. On 2 July, he achieved his first successes when he shot down two USAAF B-24 four-engine bombers over Budapest. Reschke rammed the next B-24 he downed on 7 July at 11:55 near Malacky in Slovakia when his guns malfunctioned. He successfully baled out of his stricken aircraft. On 24 August, Reschke claimed a further B-24 near Jindrichuv Hradec at 12:40, but shortly after, during an attack on a second, his aircraft was hit by return fire. Reschke wanted to force-land with a dead engine, but USAAF P-51 fighters began pouring fire into his Bf 109 G-6 "White 10" and he had to use his parachute. On 29 August, he shot down a USAAF B-17 four-engine bomber south of Zlin at 10:50. During the attack another Bf 109 fired on his Bf 109 G-6 “White 6” and Reschke had to force-land near Uherske Hradiste. By the end of August 1944, he had 14 victories to his credit. After re-equipping with the Focke-Wulf 190 A-8, I./JG 302 was redesignated III./JG 301 on 30 September 1944. In October, the unit transfered to Stendal near Berlin. On 1 January 1945, Feldwebel Reschke downed a B-17 for his 22nd victory but was again hit by return fire and baled out of his Fw 190 A-8 "White 6" east of Gardelegen. On 13 March, he was awarded the Deutsches Kreuz in Gold. In March 1945, Reschke transferred to the Geschwaderstab of JG 301. On 14 April, he flew a Ta 152 and claimed a RAF Tempest fighter shot down. On 20 April, Oberfeldwebel Reschke received the Ritterkreuz. He claimed his last two victories of the war on 24 April, when he shot down two Russian Yak-9 fighters near Berlin.
A to jego dorobek stoncen
No Date Time A/c Type Unit Location / Comments
1 2.7.1944 10:25 B-24 1./JG 302 Budapest
2 2.7.1944 10:29 B-24 1./JG 302 Budapest
3 7.7.1944 11:55 B-24 1./JG 302 Bratislava / Rammed
4 13.7.1944 10:45 B-17 1./JG 302 Neusiedler See
5 14.7.1944 9:55 B-24 1./JG 302 Budapest
6 18.7.1944 10:53 B-24 1./JG 302 München
7 18.7.1944 11:10 P-51 1./JG 302 München
8 19.7.1944 9:57 B-17 1./JG 302 Starnberg
9 16.8.1944 10:00 B-17 1./JG 302 SE Kassel
10 20.8.1944 9:45 B-17 1./JG 302 S Budapest
11 20.8.1944 9:52 B-17 HSS 1./JG 302 S Budapest
12 22.8.1944 12:50 B-17 e.V. 1./JG 302 Balaton
13 24.8.1944 12:40 B-24 1./JG 302 Neuhaus
14 29.8.1944 10:50 B-17 1./JG 302 Brünn
15 21.11.1944 12:05 B-17 9./JG 301 Magdeburg
16 26.11.1944 12:45 B-24 9./JG 301 Hildesheim
17 17.12.1944 11:20 B-24 9./JG 301 Kassel
18 17.12.1944 11:25 P-51 9./JG 301 Kassel
19 24.12.1944 14:55 B-17 9./JG 301 Hannover
20 24.12.1944 15:03 B-17 9./JG 301 Hannover
21 31.12.1944 11:35 B-24 9./JG 301 Hamburg
22 1.1.1945 12:00 B-17 9./JG 301 Gardelegen
23 14.1.1945 12:45 P-51 9./JG 301 Mecklenburg
24 14.1.1945 12:55 P-47 9./JG 301 Kyritz
25 14.4.1945 19:20 Tempest Stab JG 301 Ludwiglust / Tempest V (SN141) SA-U of 486 Sqn, RAF flown by W/O O Mitchell, killed
26 24.4.1945 8:45 Yak-9 Stab JG 301 Erkner area
27 24.4.1945 8:48 Yak-9 Stab JG 301 Erkner area
Victories : 27
tu jest wiekszosc na temat schematu malowania luftwaffe http://www.net.bialystok.pl/~hess/02_luftwaffe_malowanie.htm#tabela a tu troszeczke na temat lakierow i tym z cyklu "co i dlaczego" http://www.plastikowe.pl/materialy-zrodlowe/lotnictwo/luftwaffe-poznowojenny-rlm-76
Milej lektury Pozdrawiam
Model jak dotąd prezentuje się świetnie, ale golenie podwozia proponowałbym w odpowiednim miejscu okleić folią BMF, będzie wyglądało jak prawdziwy metal, a nie jak srebrna farba. Mam na myśli te... "amortyzatory".
Czesc Wszystkim.
Faktycznie przyjzalem sie tym amorkom i nie wygladaly rewelacyjnie co prawda tera tez nie jest perfekcyjnie ale znacznie lepiej
i tak oto malymi kroczkami zblizam sie do malowania. musze jedynie isc na poczte bo leniwemu irlandzkiemu listonoszowi nie chcialo sie puknac do drzwi sprawdzic czy ktos jest w domu odrazu wepchnol awizo do skrzynki. a tam sa moje farby tylko to pozostaje
Mimo wszystko milego dnia zycze
Witam i odpowiadam
Czy te koła czasem CI sie nie rozlazły?? Czy tak pownino byc wydaje mi sie że są troche za mocno roztwione...
Na zdjeciu nie sa jeszcze przyklejone dlatego to tek wyglada i zdjecie jest tak zrobione ze optycznie rozjechaly sie jeszcze bardziej. A ne pierwszej stronie jest kilka oryginelnych zdjec zerknij tam to zobaczysz ze takie byly w oryginale.
Przesłać Ci kawałek folii BMF? Jak to przykleisz to będzie wyglądało idealnie. Folia wygląda jak chrom, oczywiście mógłbyś to potem przykurzyć.
dzieki wielkie za propozycje ale zostawie tak jak juz jes na zdjeciach troche tego nie widac ale blyszcza sie bo przykleilem tam sreberko z czekolady jest ok. A no i dziekuje za troske
a no i jutro postaram sie dolaczyc zdjecia z poczatkow malowania bo to jest plan na jutro. w sumie to zaczelem dzisiaj malowac shading na calosci wyszlo nawet znosnie ale jak wspomnialem zdjecia jutro. a tym czasem. pora na relaks
Nie wiem, czy wiesz, ale kibicuję ze Spitkiem w tej samej skali . Mam podobny etap budowy
tak wiem ze budujesz spitka i czesto tam zaglondam ale cos ostatnio zaniedbales swoich obserwatorow
A tutaj zdjecia z malowania kamo
Dziekuje
ja maluje tylko emaljami revell i humbrol jakos nie prubowale jeszcze akryli ale jestem zadowolony z tych farb co prawda revell ma troszke uboga palete kolorow ale radze sobie i sam mieszam kolorki jak nie moge kupic gotowej farby. jezeli interesuja cie dokladne numery to tak zaczynajac od spodu
to revell 49 (RLM 76)
boki te plynne przejscie humbrol 28 (RLM 63)
ujasniejsze plamy gory to rozjasniony biala revell 66 (RLM 74)
a ciemniejsze to juz calkowity mix revell 68,66,odrobina 8 (RLM 83)
pas szybkiej identyfikacji revell 36 (RLM 28) a no i ciapki na bokach to to samo co zielone plamy
